It is currently Sat Aug 09, 2025 2:28 am
Post new topic Reply to topic  [ 32 posts ]  Go to page Previous  1, 2
PostPosted: Wed Aug 26, 2009 7:33 am
First name: Jim
Last Name: Kirby
Frei wrote:
Waddy, where did you get the plans for the 14" guitar? I prefer early music on classicals, and think a smaller body is better for that style.(Unless its a real old guitar like a Torrez, wow..)
And what are the reccomended books for a classical build?
It's the Romanillos plan from GAL, one of the sponsors here. Most of the plans being discussed are available there, except for the Bogdanovich/Hauser.
Jim Kirby
kirby@udel.edu
PostPosted: Wed Aug 26, 2009 9:52 am
Jim is right. I used that plan and the Courtnall book. I love the plan. I also had a lot of help from folks here on this forum. Check some of the posts from "Shawn", in the archives, on "Romanillos". Also David LaPlante, Joshua French and Colin Symonds gave me a lot of specific information that was extremely helpful. The biggest problem is cases. It's too small for any standard case. Most are made for 14 1/2" or 15" lower bouts.
PostPosted: Wed Aug 26, 2009 10:11 am
Country: Romania
I think Hiscox makes one or 2 with a 360 LB.
Build log
PostPosted: Wed Aug 26, 2009 3:49 pm
Another vote for the 1888 Torres plan (114). One mod I made is to dome the lower bout to 3 - 3.5mm. That way I did not have a problem with fingerboard transition at the body, nor did I have to thin the fingerboard toward the body. I kept the neck on the same plane as the body on the solera. I'm really happy with the results.
You can see it on my site: www.likekestrings.com
A higher purpose for wood.
Rich Smith
Issaquah, WA
PostPosted: Wed Aug 26, 2009 4:02 pm
First name: Jim
Last Name: Kirby
Oh yeah, books. I'll agree with Waddy, I like the Courtnall book a lot. He does have some areas there that are a little strange, though, like sawing fret slots after the fretboard is tapered (I'd prefer to have a perpendicular edge to register against, myself). The book provides a lot of information about a number of important builders and their builds, along with the general how-to, and that is an important part of the book's attraction.
I like the Bogdanovich book too. It provides a discussion of a mold system that introduces the concept of a lower bout top that falls away from the plane of the upper bout. This is an important part of the Romanillos guitar, and it is easy to adjust the design of the Bogdanovich form to use the feature in the Romanillos design of having the top be inside the sides, which then don't need the fall-away taper done before they are joined to the top. (Tapering the sides to match the top arch the way Bogdanovich suggests it is work.)
Jim
Jim Kirby
kirby@udel.edu
PostPosted: Wed Aug 26, 2009 10:20 pm
Thanks Waddy,
I use tissue paper backing on my spalt rosette wood. Not kleenex, but tissue you wrap stuff in. Very thin, takes the glue well, and combines to hold everyting intact while cutting. I am cutting with a knife edge roseete cutter (manual) and it works fine.
PostPosted: Fri Aug 28, 2009 3:18 am
Last Name: Fifield
City: San Jose
Zip/Postal Code: 95124
Here's the finished rosette. I cut the spalted maple on my laser - no need to back it with anything. Do you guys flood the spalted stuff with super glue to make it more robust prior to cutting it out?
Yay for Zipflex!!! bliss
Now it's time to move on to the patches and bracing...
Cheers,
Dave F.
Cambrian Guitars
Users browsing this forum: meddlingfool and 43 guests
